Old 10-22-2008, 10:19 PM   #1
XcyborgX
XcyborgX is on a distinguished road
Default Windows & Sunroof will not move
I have a Toyota Supra 86 (2.8 L). My windows and sunroof will not operate. The problem started out not working every now and then but got progressively worse. Eventually the windows and sunroof stopped working. I assume it had to be a common element like a switch and I tried swapping out switches but to no avail. I swapped out the switch in the driver side compartment. After looking at the schematics, I believe its the “Main Power Relay”; however, I do not see where it is located. In the PDF, I found on the internet, I only found a “main relay” under the hood but I don’t think that is it. Could any one tell me where is this main relay is and your opinion of the problem? Thanks in advance.
PDF
http://pdftown.net/1/1986%20Toyota%20Supra%20MK2.zip
Switches location page 556
Power Main Relay page 825
XcyborgX is offline   Reply With Quote
Old 11-06-2008, 12:55 AM   #2
lmumford8
lmumford8 is on a distinguished road
I can't help you, but if you post it on celicasupra.com, there are a lot of great owners of the mk2's on that forum that can.
lmumford8 is offline   Reply With Quote
Old 11-06-2008, 02:49 AM   #3
XcyborgX
Default thanks lmumford8
Thanks for that suggestion!!!!!!!
Old 12-31-2008, 07:34 PM   #4
supkar
supkar is on a distinguished road
There is a circuit breaker behind the driver's side kick panel. To reset it you insert a pin or paper clip. If you need to replace anything, contact me. I've got three MKII's worth of parts.
mkrpark@yahoo.com
supkar is offline   Reply With Quote
Stock '88 door windows f0cus0nmyf0cus Non-Generation Specific Questions 5 01-03-2008 11:32 PM
Tinted Windows Jason Van Dyk Non-Generation Specific Questions 6 01-14-2007 10:15 PM
Leaky Sunroof scruffboy Non-Generation Specific Questions 0 11-22-2005 12:34 PM
sunroof 87supraguy MKIII Supra 6 03-19-2005 06:44 AM
