Old 06-23-2008, 05:58 AM   #1
wlay1980
wlay1980 is on a distinguished road
Default upgrades?????
So I am going to be rebuilding my supra in a few months and I want to know if it is possible to swap in the 7m crank into my 5m block. I want to stroke the engine and bore it over. I am looking at giving it some extra power without turbo. If the 7m will not work then is there anything I can do to give it more torque and increase the CID in addition to boreing and cam profileing.
wlay1980 is offline   Reply With Quote
Old 06-30-2008, 04:08 PM   #2
Supra Goddess
Supra Goddess's Avatar
Supra Goddess is on a distinguished road
What year 5M block do you have?
You can only install the 7M crankshaft into a later model 5M block (85/86) because of the #1 main (later blocks have a wider #1 main, early blocks are thinner and the 7M crank won't work)
You'll also need to use the 7MGE/GTE connecting rods and oil pump driveshaft.
That would effectively make it a 6MGE. If you use the domed style pistons, oversized .030" over with intake and exhaust, you'll be looking at around 170hp and 180ft/lbs to the wheels.
You can get the pistons here:
RabidChimp.com - Second Generation Supra Engine Repair and Mainenance
I would look into getting the .030" piston rings elsewhere, as RC only has the chrome ones available and they are a ridiculous price right now. Or you could just go .020" over, bc he has those style rings for $96.
Check supramania.com for a crank, rods & op driveshaft
Supra Goddess is offline   Reply With Quote
lexus parts for supra upgrades TargaMKII MKII Supra 2 04-06-2006 12:57 AM
upgrades twd420 MKIII Supra 1 03-16-2006 08:56 PM
intercooler\ turbo upgrades cobrakiller MKIII Supra 2 11-21-2005 06:41 AM
Upgrades dcrusupra MKIII Supra 3 10-07-2005 02:01 PM
upgrades supra_91 MKIII Supra 14 10-01-2005 04:07 PM
