Go Back   Toyota Supra Forums! Join the Supra forum! > Authorized Vendors > Horsepower Freaks
Old 09-26-2005, 03:38 PM   #1
SupraMan1784
Default valves
hey jeff, what kind of valves you got for an mk3? im lookin to change the ones i got right now...let me know
Now: Saving for an MKIV
Broken Rides:
SupraMan1784 is offline
Old 09-26-2005, 07:13 PM   #2
HPF Jeff
HPF
HPF Jeff's Avatar
HPF Jeff is on a distinguished road
For the 7M Ferrea, Manley, or Toyota I'm not sure about the 1JZ, will have to check
Jeff Gore
(866) 473-5600 x 110
www.horsepowerfreaks.com
HPF Jeff is offline
Old 09-26-2005, 07:19 PM   #3
SupraMan1784
sorry, i forgot to mention it was for the 1jz...hard to find parts for a motor that isnt too common in the states, thanks
Broken Rides:
Old 09-27-2005, 04:21 PM   #4
SupraMan1784
also i just got enough money to hopefully upgrade the brakes, if you could gimme any info on any mk3 brake kits that would be great, also let me know the sizes and the brake pad compounds and if the rotors are slotted or drilled or both...and if possible can u send me the clamping force of the calipers? thanks jeff, any information would be great
Broken Rides:
Old 09-27-2005, 05:56 PM   #5
HPF Jeff
HPF
HPF Jeff's Avatar
I'm checking on the valves, but on the brakes I'd go with the Precision Bakes kit. They make a 13" front and rear kit, and a 14" front and rear kit. The rotors are 2-piece and can be blank, drilled, slotted, or drilled & slotted for no extra charge. The 13" kit has 4-piston calipers front and rear, while the 14" kit has 6-piston front and 4 piston rear calipers.
13" Pricing: $1299 front kit, (there is a group-buy on the rear kit through Raptor Racing right now)
14" Pricing: $1750 front kit, $1625 rear kit
A number of guys also do the 13" front kit and the stock MKIV tt rear brakes. Other brake kits include Brembo (~$3000 front only), Endless (~$2800 front only), KVR, etc
Jeff Gore
HPF Jeff is offline
Old 09-29-2005, 02:35 PM   #6
SupraMan1784
ill probably get the 14'' on teh front since im running 17's but im not sure if it will fit...for the precision brakes that is...hmm i forgot about using the mk4 tt rear rotors....might be a good idea...might save me so money...lemme know bout them valves though...thanks jeff
Broken Rides:
Noisy Valves spudz29212MKIII MKIII Supra 5 01-22-2009 03:37 AM
about valves cyanide-is-a-way-out MKIII Supra 2 10-03-2007 03:08 PM
Valves, Cams,& the works carfanatic89 MKIII Supra 6 06-06-2007 04:02 AM
1jz valves XTREMESUPRA MKIII Supra 0 01-17-2007 09:49 PM
Do the MK3's have blow off valves? XKeyLocX MKIII Supra 5 01-30-2006 07:06 PM
