Old 11-17-2010, 07:42 AM   #1
Jackalope501
Jackalope501's Avatar
Jackalope501 is on a distinguished road
Foam Pads:
These are glazing pads. They are also color-coded to reflect their abrasive levels, but pay attention because the colors are reversed here.
Yellow foam pads are more abrasive "cutting pads".
White foam is a fine finish pad.
Now you'll notice on the back of this white pad they put a color-coding chart on here. This is why I chose this photo. This is supposed to be the standard, but it's not always accurate. The white and yellow foam pads are consistent in their cut ratings, but the other colors are not. It's always a good bet to check the packaging and talk to the sales rep when buying blue, green or black pads.
You see here that the black pad is rated for "heavy cut" from this manufacturer. I have 2 black pads in my shop that are softer than my white ones. See my point?
Cleaning foam pads is also different. Toss them in a sink of warm soapy water and massage them. Don't use hot water or get too violent with them...the velcro is attached to the foam with adhesive. They can be a bit fragile. Rinse them in cold water, squeeze out the excess and set them out to dry.
Instead of spurring them like your wool pads while you're buffing, use a damp terrycloth towel on the pad face while you spin it at 1800 rpm.
Jackalope501 is offline   Reply With Quote
Old 11-17-2010, 08:36 AM   #2
Jackalope501
Default Buffing VS Glazing
Now that we've talked about the pad types, let's discuss how to use them. Yes, there is a big difference between buffing and glazing, and you don't always need to do both. For basic principles, let's define them both.
Buffing:
Here we're spinning a wool pad with a more aggressive product to remove oxidation and scratches from the paint at higher rpms. Normally 3000. Buffing products have different levels of silicates (sand) in them to accomplish this. Heavy compounds will feel gritty between your fingers like toothpaste, while products like Malco's Lite Finish will have more of a hand lotion type consistency.
Glazing:
Now we're spinning a foam pad at lower rpms, around 1800, with a wax or polymer based product to seal the paint, remove swirl marks and/or enhance the shine on the car's finish.
The buffer speed combined with the material of the pad produces heat that's used to break down the product and push it into the paint. Buffing products break down at higher heat than the glazing products do, which is why we glaze at lower speed settings.
When to buff or glaze?
Let's say your paint feels dry to the touch. You put your hand on the hood palm down and pull it to you and it sounds like this...eeeeeeeeeeeeeee. But the paint isn't oxidized or scratched up. Glazing it will do. Glazed and waxed paint will feel soft, warm and smooth.
If you have oxidation(chalky appearance) and scratches in the paint, it's time to buff. The standard rule of thumb is this...if you can prick the scratch with your fingernail, you won't get all of it out. I've compounded deep scratches out of cars before, but you're gonna burn through some layers of paint to do it. Not something for an inexperienced person to attempt. Buffing creates a lot of heat and friction, so burning the paint is easy to do. You can destroy a car's finish quickly if you don't know what you're doing, which is why I recommend you start by glazing until you get the hang of it. Everybody burns cars while buffing. Anybody who says they haven't has never buffed.
Two types of burns:
Working burns- These occur due to failing paint or clearcoat, or around sharp body panels where the paint is extremely thin. One simple pass can do it, and you won't notice it until the damage is done. Oops, now you gotta fix it...
Neglect burns- These occur due to an idiot with the buffer who stays too long in one place, or grinds the edge of the pad against the paint. An example would be buffing around a spoiler and bumping the pillar with the edge of the pad. That's why we do those areas by hand, and you always mask rubber body trim. Now it's time to fire somebody...
Now here's where it gets complex. Let's say we've got a dark green Chevy truck to work on. Fairly common color for them, right? It's got some oxidation and a few fine scratches. We can buff this out with Lite Finish and a wool pad, wax it, and be done.
Next we have a dark green Nissan truck with the same problem. Once we buff it out with Lite Finish and a wool pad, we'll have to glaze it with a foam pad and Phase II glazing product before we can wax it.
Why? Because GM uses a harder clearcoat than Nissan and other auto makers do. Softer clearcoats are prone to swirl marks after you use a wool pad on them, especially with darker colors. Lexus black is a bitch.
We'll cover that more later...
Tomorrow I'll start covering buffing and glazing products...
Old 11-17-2010, 02:31 PM   #3
Jackalope501
Buffing Products:
There are hundreds of products out there making all kinds of claims, so let's boil off the fat and use what really works. From a professional standpoint I use Malco products like Lite Finish:
Lite Finish is the product I use on most buffing jobs. Combined with a wool pad, this will whack out most paint imperfections like oxidation and scratches. You can buy this stuff in several sizes, so I don't recommend the gallon unless you have a shop. You can get pints and quarts. A pint will do most cars used corerctly. (with an applicator)
CAUTION! Do NOT store buffing products in a cold garage! Once they freeze, they separate...then the shit is worthless. Protect your investment by keeping them in a warm place.
Ok, so you may not have access to Malco products, what then?
Meguiars makes some pretty good stuff as well, and you can get it anywhere. They also make heavier compounds, but this is the one we'll compare to Malco's Lite Finish.
If you have to go heavier because Lite Finish or Meguiars isn't pulling it out of your paint, then these are our options...
Meguiars Heavy Cut Cleaner:
Or what I use myself, Malco's Tru-Grit:
Also available in several sizes...gallons are for shops. Honestly, I'm almost reluctant to advise on these products to anyone without buffing experience, but we'll cover more on that as we go. Suffice it to say this shit can do some serious damage to paint if you use it incorrectly, but it pulls out shit you would not believe.
Last edited by Jackalope501; 11-19-2010 at 10:13 PM. Reason: Addition of more info
Old 11-17-2010, 04:43 PM   #4
fantasma87
fantasma87's Avatar
OMG this is like the bible for detailing. can wait to get back home and start on mine.
ARMY STRONG !!
Old 11-18-2010, 07:06 AM   #5
crazyasianr6
crazyasianr6's Avatar
crazyasianr6 is on a distinguished road
By far the best detailing advise ive ever read up on. i worked at a detail shop for a year, but never got to do much with exterior. thank you again for this awesome contribution.
crazyasianr6 is offline   Reply With Quote
Old 11-19-2010, 09:41 PM   #6
Jackalope501
You're welcome...just trying to help guys. So much bullshit info out there makes it hard for people to get the right stuff...
Scroll back guys, I'm finishing out the post on buffing products above...
Let's start using your buffer....
Remember wetting and wringing out our applicator pad for waxing? Same process here. Wet and squeeze your applicator for applying your buffing product. It's also a good idea to shake up your products too...not just when you buff, but you want to agitate it a bit whenever you walk past it on the shelf. Keep it from settling or separating on ya...
Area coverage:
You can only work a 2ft x 2ft (approximate)area on the car at one time. to give you a better idea, let's use a Supra hood as an example. You have 3 distinct areas from one side to the other divided roughly in 3rds. Your 2 lower laying sides and the raised section in the center, right? Now take each one of those and cut it in half from the hood's front edge at the nosecap to the base of the windshield. That "1/6th" of the hood is all the area you can manage at once.
(Let me know if you need pics here to demonstrate)
Buffing products are designed to be applied wet, and worked while wet. Don't let them dry like you do wax.
Don't delay once you apply product to the hood. If your pad needs cleaned, spur it first...have the buffer ready to go once you put the product on...
Since we've already mentioned the hood, let's start there. This is one of the easier parts of a car to buff. I recommend starting on one of the outside "3rds" of it here for easier control. (Once you've practiced a bit, you'll typically start at the center section and work out to avoid touching the same area twice.) Be sure to drape your buffer's cord over your shoulder so you're not dragging it on fenders, etc. While I'm on that, never wear anything harder than sweats when you buff a car. No brass rivots on your jeans, no belt buckles, NOTHING that can scratch the car! Sweats are always your safest bet. Trust me, you're gonna be getting intimate with your car here and leaning all over it.
Old 11-20-2010, 10:10 PM   #7
Jackalope501
Default Buffing the Hood
You have your dampened applicator and buffing product in hand. Place about a quarter-sized dollop on the applicator, and wipe it on the 1/6th area we talked about earlier. Set your applicator aside (face up) and grab your buffer. (wool pad attached, 3000 rpm) Pull your trigger and set the buffer down flat on the surface you're buffing...moving side to side with the body lines of the hood, then back and forth to cross your patterns like a big "T". Keep your buffer moving at all times. Work this area until the surface comes out clean. Don't overdo it. You may leave a couple of small smut marks where you didn't get all the polish off...that's ok. Better to leave a couple of spots than attempting to grind them out.
Be particularly careful around windshield wipers, washer jets, trim, antennas, etc. the edges of your wool pad can snag one in a heartbeat and sling it across your shop. I'm not kidding. I've seen fuel doors, trim, rearview mirrors and hood ornaments ripped off of cars before. It happens in a nanosecond, so always be aware of your pad's proximity to hazards.
Practice that for a bit, and we'll pick up again later...
Current Ride, Mustang 5.0 cageceo Show n Tell 28 08-10-2007 08:15 PM
Car Paint Maintenance, and cleaning. cageceo Exterior , Interior, and Detailing 1 08-09-2007 05:43 AM
