Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Drifting
Old 01-08-2007, 03:37 AM   #1
dom747
dom747 is on a distinguished road
Default drifting
hey iam really into drifting and i just got a 86.5 supra non turbo ....i was wondering...if i were to swap the engine to a 1jz or a 7mgte...what eles would i need to do to get it more of a drift ready kinda car
dom747 is offline   Reply With Quote
Old 01-08-2007, 04:46 AM   #2
tone loc
tone loc's Avatar
lsd diffrential
if its an auto your ganna want to make it stick
Old 01-08-2007, 05:23 AM   #3
JimmyH
JimmyH is on a distinguished road
Smile
get a good seat that holds you well. Many factory seats do offer good support but lacks of lateral and thigh support. By using 4 point or more seat belt can help a lot in holding you in place. there is a huge side way forces while you are in a drift; with a good seat and proper seat belt can reduce the chance of mis-shifting. When you are being secured to the seat, you will be able to focus on driving morn than trying to keep yourself in place~~
JimmyH is offline   Reply With Quote
Old 01-08-2007, 07:25 AM   #4
Murd
I'd suggest some adjustable coil overs as well.
Old 01-08-2007, 05:13 PM   #5
dom747
awesome...ya my car is a 5 speed man...would i have to change the rear end or anything, and like engine wise....what would be best?
Old 01-09-2007, 01:22 AM   #6
drifterkid240
drifterkid240 is on a distinguished road
if you dont have a diff... get one, i remember learning on a bone stock car and it sucked until i got a diff and some coilovers so i would say start with that and get used to drifting before getting into the high speed stuff like 70mph+ into a corner
and i dont know if you know how but form the sounds of it you are prolly just starting out.
helping hint to get better fasted than i.
step 1, get a cone and a wide open parking lot and start off doing 180's around the cone, for this to work you will want to pull the e-brake and turn the car. work on going left and right with the 180's
step 2, when you have mastered the 180 you go to 2 cones and do a figure 8 and once you get down the weight transfering form side to side and your not using the e-brake to turn the car around the cone and your just using the clutch and gas to turn the car you can now move on to the street, opps wait, wait, did i say street??? i meant track yes find your local speedway and see if and when they will be having a drift day and have fun.
P.S. get an extra set of tires i for some odd reason cant stop going through tires and i have an extra set of tires???? wonder why????
drifterkid240 is offline   Reply With Quote
Old 01-09-2007, 06:18 AM   #7
dom747
well ive been drifting for a while...like in my lil nissan...and doing corners and s's but i just got my first car that i wanan doo up and accually make it real drift worthy, but thanks on those tips...soo ya...and that engine...like what would be best?
Old 01-11-2007, 02:32 PM   #8
JimmyH
Smile
I'm not too fimilar with 1JZ but I believe the parts for it are cheaper to aquire in comparsion to upgading a 2JZ. If budget is not too big an issue, try to find a reliable or rebuilt 1JZ to swap in in order to have a worry free power source. I've seen many people spending more time by the track side fixing cars instead of having seat time practicing drifting~~
Engine wise, make sure your cooling system is sufficient enough. When you drift in a smaller places; the heat soak is really the main issue that causes over-heating. So a big volume radiator and higher pressure cap are really good investments. Also, ARC offers a "Radiator Breather Valve" that provides you an additional insurance for cooling. Electric fans are good but it's up to you whether to upgrade it or not; many cars work just fine with factory fans of course. Just remember, do everything that helps in cooling the engine bay will be my best suggestion to you~~
enjoy drifting and I wish you the best ~~
Old 08-09-2008, 11:05 PM   #9
C0o0n
C0o0n is on a distinguished road
were did you get the lsd
C0o0n is offline   Reply With Quote
Old 08-10-2008, 12:35 AM   #10
supra_91
supra_91's Avatar
if you want to dedicate your supra for drifting then you need shed some fat off of her. she's pretty hefty, 3500 lbs. hefty.
automatic tranny and drifting x3jj3x Drifting 23 07-15-2009 04:32 AM
video of my mk2 drifting jrok Show n Tell 1 01-30-2009 06:36 PM
R/C Drifting davidbeau Drifting 0 04-18-2008 05:44 AM
more drifting footage west_side_supra Drifting 1 07-23-2007 11:40 PM
more drifting footage west_side_supra MKIII Supra 1 04-14-2007 11:45 PM
