Old 03-18-2009, 10:06 PM   #11
sigep233
sigep233 is on a distinguished road
Originally Posted by defiant View Post
Hey, you guys are really helping me out here, but what does "rms" mean? I went into a stereo shop and they were talking rms and ohms and crap I have no idea about.
RMS stands for Root Mean Squaired. to put it another wat that is the constant power the amp produces. the max is the power it can produce at any given time but the actual power rating you want to look at is RMS
Take it from me i am MECP advanced certified!
sigep233 is offline   Reply With Quote
Old 03-18-2009, 10:14 PM   #12
sigep233
Check it out. if you series speakers together you will raise the ohm load (4ohm + 4 ohm =8ohm) parallel (4ohm +4 ohm = 2ohm)
"mono block" amps are 1 ohm stable, with the lower the ohm load the higher the power produced. so to answer your question you need to find out
1 how many subs you want
2 are they dual or single voice coil
after that calculate ohm load to see if you purchase the 2,4 or 8ohm subs
Old 03-18-2009, 11:27 PM   #13
mastergrader007
mastergrader007 is on a distinguished road
not all mono block amps are 1ohm stable! i have one that is only 2 ohm, and learned that the hard way. I also used to compete SPL with an old Orion HCCA 225. it was classed as 25w x2 but it was 1/2 ohm stable. it was about 600w loaded down
mastergrader007 is offline   Reply With Quote
Audio and a lot of other things wrong with car bluemeate MKIII Supra 4 05-18-2010 07:07 PM
ohms rating for factory speakers whowouldfigga Car Audio and Alarms 0 04-13-2008 07:01 PM
Sensor ohms Metalshredder_25 Non-Generation Specific Questions 3 09-27-2006 04:03 AM
audio for 87 supra y8Dgr8 MKIII Supra 5 07-09-2006 12:30 AM
