Old 03-14-2007, 12:04 AM   #1
kylesupraturbo
kylesupraturbo is on a distinguished road
Default Stereo Removal????
hi there,
it may be me being thick but how is it possible to remove the stock stereo out of a mk3?
any help will be appreciated
kyle
kylesupraturbo is offline   Reply With Quote
Old 03-14-2007, 05:20 AM   #2
plaaya69
plaaya69's Avatar
Arrow
You need to remove the radio shroud(the big black plastic almost like rubber peice that holds the ash tray and the cig lighter) once you remove that it will be very easy to get to.
Old 03-14-2007, 09:14 AM   #3
kylesupraturbo
hi there,
thanks for the reply, how could i remove the rubbery shroud without breaking it??
cheers
kyle
Old 03-14-2007, 12:46 PM   #4
plaaya69
plaaya69's Avatar
You need to remove the two screws and then once you remove them then you just carefuly pull it out. Try and get the bottom loose first then just try and pull it out. Hope this helps.
Old 03-14-2007, 04:57 PM   #5
Caliturbo88
Caliturbo88 is on a distinguished road
also... you SHOULD be able to pull it off without any prying. the two screws are down by the shifter. then once that is off, you undo 4 small bolts around the radio. its pretty self explanitory once you get that front piece off
Caliturbo88 is offline   Reply With Quote
Old 12-17-2008, 06:10 PM   #6
SupraSean
SupraSean is on a distinguished road
when i took my radio out, i took out all the screws to that shroud that covers the shifter and runs up the dash, i think theres actually like 5+ screws, then just unbolt the radio and unplug.
SupraSean is offline   Reply With Quote
anyone install aftermarket stereo? dannydavi Car Audio and Alarms 10 03-17-2012 10:41 PM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Stereo Removal Kai MKIII Supra 10 04-18-2006 02:16 AM
factory stereo monkihead Car Audio and Alarms 0 04-02-2005 08:57 PM
