Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Car Audio and Alarms
Old 10-03-2011, 03:56 AM   #1
Jamie-b
Jamie-b is on a distinguished road
Default Upgrading Central locking to keyless entry
Hi,
After a long search for a kit to convert my central locking to key less entry, that came with a flip key, i finally found one, then after a long wait i finally received it, however as its a universal kit, the instruction are pretty poor..
And by instructions i mean there are none.. however it does have 4 Diagrams..
One is just for windows automatically rolling up, lights flashing, shit like that.
Then there is 3, which im guessing only 1 is for my car,
They are labeled "Positive trigger, Negative Trigger, Positive and Negative Trigger"
Ive been told the supra is negative trigger?
I also need to know where the "Central locking system" is located, and what wires are for lock and unlock signal?
Here is a diagram that was supplied for negative trigger
Jamie-b is offline   Reply With Quote
Old 10-18-2011, 11:00 AM   #2
N2Dee74
N2Dee74 is on a distinguished road
Depends on the Model. For the MKII Supra, I believe it is in the drivers side kick panel. Here is a link to the manual that shows electrical connections. http://www.cygnusx1.net/Supra/Librar...aspx?S=BE&P=68
Where did you get the lock kit, I'm interested!
Cheers,
Brad
N2Dee74 is offline   Reply With Quote
central locking relay theboy641 MKIV Supra 0 01-20-2010 03:45 PM
Factory Keyless Entry suprajim MKIII Supra 1 11-04-2009 02:54 AM
Body Conrol Module + Keyless entry kit help? FL850 MKIII Supra 0 09-28-2009 09:24 PM
how do i make the hatchback keyless entry work? ogkush Non-Generation Specific Questions 6 02-21-2006 11:18 PM
central locking kixxx MKIV Supra 1 01-05-2006 02:22 PM
