Old 12-12-2011, 12:24 AM   #37
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by [SupraLEGEND] View Post
Right, to put it simply - a clutch disk is known as a clutch plate and those are referred to as single, twin or triple depending on the number but, there is only one pressure plate present. Right or wrong?
Twin, triple, or quadruple clutches have multiple clutch disks/plates and multiple floater plates. Clutch disks/plates always have friction material on them, but the pressure plate, floater plates and flywheel surface usually do not (except in the case of 'triple-carbon' clutches).
Here's an example of a quadruple disk, 'triple-carbon' carbon clutch:
http://www.titanmotorsports.com/tiqudifor93s.html
It is literally the most expensive clutch for the Mkiv Supra Turbo (w/2jz-gte and V160). It has four clutch disks, three floater plates, and sixteen surfaces with carbon-fiber friction material.
Here's another top-of-the-line clutch for the Mkiv Supra Turbo. It's RPS' triple carbon:
http://www.turboclutch.com/Pages/RPS%20BC3M%20LSX.htm
In this illustration, you can more clearly see all of the clutch disks and floater plates.
Life begins at 30psi.
