Old 12-02-2011, 12:22 PM   #1
Turboron_99
Turboron_99's Avatar
Turboron_99 is on a distinguished road
Wink
Regardless, if you replace the oem rubber-like and plastic intercooler piping with (preferrably) aluminum piping that follows the same path, you won't need to re-tune at all. I'd recommend against steel piping because it's too heavy, and you don't need steel pipe to hold <40psi of air pressure. Be sure to use silicone couplings and t-bolt clamps.
Dont forget Steel will be alot more Prown to Heat Soak than nice Aluminum! Plus putting a rolled in Beed on Steel would be a PITA! Would probably have to weld a beed to the pipe!
Turboron_99 is offline   Reply With Quote
