11-29-2011, 10:49 PM
#31
Supra Owner
Thank you for the additional information about Japanese-spec Mkiv brakes. Much appreciated.
Overall note: My purpose is to help protect you against the sellers here, that *may have* overstated the degree to which they have upgraded these cars. I'm also trying to educate other readers of this forum who may end up in a similar situation. My purpose is not to, for example, win an argument against you. I'm only trying to point out some things you may not have considered, given the limited information that you have posted here.
Originally Posted by [SupraLEGEND]
Your statement about "too much money put into the suspension" is far off....
Disagree. In fact, now that you've shared your application I'm more convinced than ever than Ohlin shocks are overkill beyond overkill - waaaaaay too much suspension for your needs. Please consider the following:- The oem shocks have been successfully roadraced.
- Minor suspension upgrades (Eibach springs and KYB shocks) have been successfully roadraced.
- Modest coilovers (HKS or Ground Control or Tiens) have been very successfully roadraced.
- You only need to go to the level of Penske/Ohlin/Moton shocks if you're a hard-core advanced amateur or semi-pro.
For your drag/street/track application, something like Eibachs and KYBs would fit the bill perfectly. At this level of suspension upgrade, your Supra's performance would be superior, and you would take great advantage of its capabilities. I suspect you'd get many years of great use out of that set-up before you would need to upgrade.
...You can clearly see from the mod list that, the '95 Supra has APU engine upgrades. More power was clearly an emphasis with necessary attention being paid to the suspension which is very important for better handling of that extra power...
Too bad they didn't see fit to upgrade the brakes too...at least with US-spec rotors and calpers, if not something even better aftermarket (Brembo, AP Racing, Stoptech, Rotara, etc.). *shrug* With more power you don't just need to corner quicker, you need to stop quicker too.
...racing pads are not subjective. They genuinely improve braking performance. Better compounds = better grip onto the rotors which makes stopping easier and more precise. It'd rather have just a racing pads upgrade than no brake upgrade at all. This of course is unnecessary on the original '93 RZ 6MT because, it's not pushing far more power than stock so it's brakes are definitely good enough...
Disagree. The reason I say this is because there's no such thing as a "racing" brake pad. The term is far too general. Give me the specific company name that makes the pad (eg. TRD? Carbotech? EBC? Brembo? Project Mu? etc.), and an exact compound specification and then we would actually have something that we can evaluate. Without that, a "racing" brake pad can actually hurt performance. For example, some of the 'EBC greenstuff' pads actually perform worse than oem, but some might consider them to be "racing" pads. Folks usually buy 'EBC greenstuff' pads because they create less brake dust than the oem pads. In fact, the oem brake pads really are quite good for braking performance, even in an on-track roadracing scenario.
You must agree that Supra is exhilarating in both forms (moreso modded)?...
Agree: the TT is exhilarating. The n/a is merely something nice to look at.
I notice you use the word "inferior" when talking about N/A's - the TT is certainly superior but, don't you think that's a bit harsh against the N/A?...
Not in the least little bit. If the n/a version were never made, the Mkiv Supra Turbo would have achieved a much higher ranking as an unequivicably 'affordable mid '90s supercar'. The Mkiv n/a's components are, to me, not much better than what you'd find in (for example) a Solara...which is by no standard a 'sportscar'.
Life begins at 30psi.
