Old 11-26-2011, 02:55 AM   #8
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
1) Can use the oem fuel tank must just get one more pump in the system...
Thank goodness. Putting a second fuel pump into the oem fuel tank is quite simple:
http://www.mkiv.com/techarticles/fue...DualPumps2.jpg
Please go ahead and sell that fuel cell.
...2) Its basically that know its not a good make but the brand names are very expensive and cant find any 2nd hand ones....
Please post up a picture of it.
...3) would like a decend speed if not much of a change...
Please be more specific. What is a "decent speed" to you? 150mph? 175mph? "a decent speed" is too subjective, so we would either have to competely ignore that goal during the build, or you need to decide much more exactly what you want to achieve.
...4) nos is very difficult to full up and dont want to use it...
Hmmmm. This could significantly impact the cost. To me "very difficult" is not the same thing as impossible. Personlly, I would put up with something difficult if it meant saving a significant amount of money...
5) Would like to go single turbo....
Okay, but is this a build requirement, or not? If we could save money by getting you into the 10s without a single turbo, would you consider it?
...6)would like to use the parts i bought also the fuel is crap this side and seen good results with e85...
okay, but what about the gotech pro x ecu? Would you sell that if it turns out we don't need it at all?
Also, please post a link where I can learn more about this ecu.
...7) Have not spend alot of time on the flywheel to busy at work.
Ok. Please post a picture of how far you've gotten on this project.
Life begins at 30psi.
