Old 11-05-2011, 01:33 AM   #2
LOL. Well, given that no Supra (prior to the MKIV) ever came with a MAF it's unlikely you'd ever see one... not that you can't convert to a MAF if you wish; That's what the original MAF-T and the MAFT Gen II do. The Supra has either a VAFM or a KVAFM. Now if you're talking about the 1JZ-GTE or 1G-GTE then they run Speed/Density using a MAP sensor and an IAT. The 2JZ-GE used a KVAFM (at least in the earlier years). (((It's not relevent to this thread, but the 2JZ-GTE in the MKIV did use a "hotwire" type MAF))) There's a big difference between all of these. The generic for a KVAFM or a VAFM would be just AFM. (If you want more specifics I've covered this one very thoroughly in the past... practically wrote a paper. Might try searching Karman Vortex.)
EDIT: Hell, I can't find the big post on it... I may have deleted it for being too verbose or it may have been in a thread which was deleted. These posts have more info:
http://www.toyota-supra.info/forums/78657-post14.html
http://www.toyota-supra.info/forums/86910-post6.html
At any rate, yes, the MAFT Pro supports Speed/Density (MAP/IAT) setups. It calculates airflow by measuring manifold pressure and air temp so all you have is a sensor connected with a vacuum hose and a small temp sensor in the piping. One big difference is that this setup calculates air flow it doesn't actually measure it... again it's a big difference whether you understand why or not.
IMHO, Running a nice big GM MAF in a blow through setup is a little less sketchy and good bit easier to setup.
EDIT: And yes, I am picking on you. I had actually already answered the question with the statement that most standalones will do the same things (and then some).
EDIT2: Actually, I'm wrong. The 2JZ-GTE in the MKIV did use a "hotwire" MAF. My bad. I thought they ran S/D.
