Old 10-21-2011, 12:58 AM   #34
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
The managment im gone use has 6 outputs.Can you give me some advise on the stock flywheel to look if it is really necessary to replace it.
If your current (used) oem Mkiv TT flywheel has play in it, then it's probably time to get a new oem flywheel. For drag racing, the oem flywheel with a strong aftermarket pressure plate and carbon-puck disk works fine up to about 700rwhp. At that point, you need to move to a twin disk clutch in order for it to reliably and repeatedly hold hard launches. All twin clutches come with their own flywheel.
Life begins at 30psi.
