Old 09-19-2011, 07:54 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Il keep the head gasket on il just upgrade the fuel system.how strong is the stock clutch and flywheel.can you tel me what the diffrence is between e85 an ethanol.thanks for the advise so far you have been a great help.
Then oem pressure plate will only hold about 400rwhp* long-term reliably. With an Act or RPS or South Bend pressure plate, the oem flywheel and clutch disc will hold about 600rwhp*. With a carbon-ceramic clutch disc, it'll hold about 700rwhp*. Above that point you'll need a double or triple disc clutch.
A lightweight flywheel will improve roadracing performance, but it will not affect holding power.
E85 is 15% gasoline. Pure ethanol can be the start of a great party!
* P. S. Clutches actually hold torque, not horsepower. If you'd like the upgrade points in ft-lbs instead, please send me a PM.
Life begins at 30psi.
