Thread: RPM to shift
Old 09-18-2011, 01:59 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by deigima View Post
i think he might be refferring to theshifting points for just cruising around. when your driving a car hard, you shift at higher revs to use as much of the power as you can, but to shift at 6grand while just driving to the shops, isnt going to do good for any engine in the long run.
in my opinion, for cruising 3grand shifts should be fine, it doesnt hurt the car to drive it like that.
1) It's an Mkiv Supra Turbo. If you maintain it and shift it properly, it's built to handle high performance driving. That's what makes the car so special!
2) Anything other than the shift points I posted is just half-@ssed semi-perrformance screwing around. Don't ask a serious question if that's all you want to do.
Life begins at 30psi.
pwpanas is offline
