Old 09-16-2011, 04:02 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
peoplei n SA is advising me against ethanol is afgas just as good or not.How good is the aftermarket intake manifolds on ebay peolple also say it is crap because it gets smaller at the end and cyl 5.6 runs hotter can build my own just need spec. do i need to make my fuel lines bigger for 1200cc injectors.any advise welcome
Do not run aviation fuel. Race fuel (specifically for motorsports applications) is proven for high horsepower applications. E85 is okay too.
The oem plenum is what causes a lean condition in #6 for high horsepower applications. Aftermarket plenums solve this issue. That's why they were invented! However I definitely agree that you should stay away from the cheaply-constructed plenums on ebay and go with a name brand like veilside, virtual works, or sound performance.
I can't answer the question about you fuel lines because you have not told me how much fuel your engine will be consuming. For example, I could make 1200cc injectors work just fine with the stock twin turbos and the oem fuel lines. If you still have that 67mm turbo, 1200cc injectors are too big unless you're going to run E85. A 67mm turbo's fuel requirements do outstrip the oem fuel pump and lines. You need to get a complete fuel system - don't try to piecemeal one together yourself.
Life begins at 30psi.
