Old 08-28-2011, 11:26 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by winnas13 View Post
I think you're right. I hope the supra hasn't been road raced! The wheels are pretty wide though at the rear - Khumo tyres 265/35Z R18 97Y XL (that means nothing to me)
Is a wheel bearing expensive to be replaced/fixed?
Unfortunately, yes. Typically, the hub is removed, the bearing is pressed out, the new one is pressed in, the hub is reinstalled, and then you need a new rear alignment. Not a trivial task.
Life begins at 30psi.
