07-30-2011, 10:53 AM
#10
Supra Owner
Originally Posted by Mk3FirstCar-Mike
I've read a few things and it seems to be about 3 quarts of methanol - 16 gallons of gas, but I don't know where to get methanol in the first place. As for the window washer fluid, some of it does contain about 35% methanol, but I have no idea if it's safe to use in the injection system. I'll keep digging, though.
With a separate meth injection system you can make at least 650rwhp (6spd) on 93 (r+m)/2 pump gas.
You can get meth direct from gasoline distributors - the same place you get pure race fuel in barrels. You can also get 1-gallon tin containers of denatured alcohol from home supply stores that work in alcohol+water injection systems too.
Life begins at 30psi.
