Old 07-29-2011, 09:56 PM   #1
a400tool
a400tool's Avatar
a400tool is on a distinguished road
Originally Posted by El Supracabras View Post
After you have checked what is mentioned above, check all your hoses. A small hole in a hose may not leak coolant but instead suck in air while coolant is circulating. This will cause an air pocket and it will puke coolant out soon after. Its usually a sign of air in the system if the temp goes down when driving and up when stopped. Make sure you have the heater on when filling the system to purge the air out of the heater core.
I've done all that as well. I will recheck the turbo coolant hoses to be sure.
Thanks.
a400tool is offline   Reply With Quote
