Old 07-20-2011, 09:39 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 792 View Post
If I were to take a stock mkIV with a 2jzgte, and put somewhere in the range of $7,000(Mostly at a shop, some simple things I will do myself If there are such things) into the car what RWHP could I expect and what specs could I expect out of it? Going to be swapping in a low mileage jdm engine with a 6mt, but this $7k will be ontop of the new engine. I would like to have it still streetable and it will mainly be for roadrace/occasional 1/4 mile. Let me know what you guys think I could get out of it and thanks in advance.
Also, this is my first post so hey everybody!
Labor can be a big part of the cost. If you're not very experienced with the Mkiv Supra Turbo, you shouldn't attempt the work yourself without months of reading tech articles and forums, and then having the TSRMs by your side. That $7K works out differently if you have to pay an Mkiv TT experienced mechanic to do the work, or the $7K is parts-only.
Why swap in a jdm engine? Sure, the mileage might be lower, but the hours on the engine will probably be higher. Time spent idling (and revving) on the constantly-jammed streets of Tokyo is a big factor.
Just offhand though, if you're going to both roadrace and drag race it, you're probably looking at a bpu+++ Mkiv at best for that max amount...which means about 425rwhp at best, reliably. Imho, there's no way you get a fuel system and an aftermarket turbo system on the car for that price, and then still have the $ you need for clutch, rims&tires, race fuel, and all of the other odds-and-ends you'll need for roadracing and drag racing.
Life begins at 30psi.
