Old 07-12-2011, 09:06 PM   #1
87supra7mgte
BHG is a good idea, best way to check that is to let the engine cool all the way down and remove the radiator cap, start engine and see if it bubbles as the engine warms up, if so gasket is bad or head is cracked, as for the hard startup, im having the same issue when its cold, i think it might either be a clogged fuel filter or a slight leak in the gas line causing the car to lose fuel pressure
87supra7mgte is offline
