Old 07-03-2011, 10:51 AM   #1
marezmichael
marezmichael is on a distinguished road
Originally Posted by 97SupraTT View Post
Are any warning lights coming on? You could try to disconnect the battary, dry the terminals (probably shouldnt be wet anymore anyhow) let it sit disconnected for a lil while and then reconnect and see if that helps. Not sure if it will though.
the warning light above the tach.. and also the temp warning light?
but i will disconnect dry off, and re-post if problem still occurs, thanks for the help.
marezmichael is offline   Reply With Quote
