Old 06-08-2011, 01:01 AM   #1
tayman1975
tayman1975 is on a distinguished road
Default What do you mean by avoid the perenial.
either way this guy would owned it was an idiot. The sterio wiring harness was cut so short that i had to add wires onto it to hook up a deck to it. Then the stupid idiot cut the speaker wires on the back ones so short that he gave me 1 inch of speaker wire to play with in between the seats. i had to use a pair of pliers to hold it up so i could krimp up a butt connector to it. It took all day to fix the mess he made. have you ever heard of a high performance clutch ratting when the clutch is dissengaged. It sounds like the thowout bearing is f-cked. he told me the clutch makes that noise,(rattle). Is he right there. He also told me the engine is brand new and needs breaking in so he had the rev limiter set at 5000rpm. So now the car goes in on the 21st to get the rev limiter removed. Do you think something fishy is up with my supra i just got from this guy. I never heard of a rev limiter being set for a new build before. It's a good idea but never heard of it.
tayman1975 is offline   Reply With Quote
