Old 05-19-2011, 02:32 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Put it to TDC then check cps again. If its backfiring then either that is off a tooth or plugs on wrong. Only check the cps if u had it out. If u didnt then it couldn't have jumped. Also check the vacuum line under the intake. That little one always got me. Make sure coil pack mount is grounded to the valve cover or anywhere u choose really but that's the factory location.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
