Old 05-19-2011, 03:04 AM   #1
87supra7mgte
Default a few ideas
check your coils, make sure the right connector is plugged it, mines a green connector, only one on that side of the engine, check wires inside of CPS to make sure they didn't get frayed or cut, make sure they are grounded out should be a wire coming from the driver side of it that grounds to the head, plug wires in the right order, from left to right it should be 1-6-3-4-2-5, is that all you have is the downpipe? none of the exhaust connected? that could possibly have been the noise, but if it was that loud idk, refer to a manual to properly adjust the CPS, it was the reason mine wouldn't start after i replaced head gasket/turbo
