Old 05-03-2011, 04:03 AM   #23
ochowdero
Originally Posted by 87hilux7mge View Post
hmm, have to read up on that part in my haynes. never had a manual suggest different weight oils and change intervals like that. normally since theres no combustion cycle and deposits to soak into the oil, it doesnt need changing. i guess due to initial wear you could have a small amount of metal particulate, but not enough to cause a problem the magnetic drain plug cant contain. but whatever the manual says
as for the wires, yep that sounds right. makes a constant circtuit so the car thinks its in neutral and will idle when off throttle or while sitting.
i went to kragens today to check the prices on oil, they ran my car into the computer and said it was 70w
is this true? i would assume so but just double checking...
EDIT: i checked TEWD and i have no clue what wires to jump?? HELP i remember BTWILSON said it was blue and black or something... idk exactly..
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
