Old 04-23-2011, 07:41 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Thanks for the advice so far its been very helpful.
What cam wil you say is the best to use and wat can i rev the motor safely.
You're welcome.
For your application, these HKS 272 duration cams will do nicely:
2202-RT085 and 2202-RT086
(note these only work on the '93-'98 non-VVTi models)
With the oem valve springs, max 8500rpm is safe.
With dual springs and titanium retainers, 9500+rpm is easily doable.
Add shimless buckets to the setup and it should be good for 11K (no kidding - again, that's with a bone-stock oem shortblock!).
However, note that you don't really make your power with rpms alone in the 2jz-gte. The turbo is so integral to the overall performance...the turbo-driven horsepower curve will usually taper off after about 8000-9000rpms. You'll want to set things up so that your shifts maximally captialize on that horsepower curve. Use the nos as an aide to spool up the turbo quicker and you'll widen that horsepower curve even more.
Life begins at 30psi.
