Old 03-30-2011, 02:15 AM   #3
I will give you three answers and I'm ignoring your posts thereafter.... it's just too damned painful.
1) Test the dimmer for gauge lighting. Just pull it out and jumper the White wire with green stripe to the White wire with the black stripe.
2) Test/replace the radiator cap and test the pH of the coolant to make sure the HG didn't blow again... just because you just fixed it doesn't mean that you *fixed* it.
3) 50/50 coolant is premixed, you do not add more water to it. It's not going to do any short term damage in warm environments but does not protect against dielectric erosion as it should.
-Goodbye.
