03-27-2011, 09:03 PM
#1
Originally Posted by jowintt01
Just finished 7MGE swap to 7MGTE motor fired up fine,just one issue motor has a miss sounds like bup bup intermittently also at the exhaust tip,motor has 60000mls check torque came it at 75-80lbs boost leaked checked and replaced hose clamps,coil pack good new plugs all firing good,I had two suggestions #1 replace fuel pump- injectors are not getting enough fuel,#2 possible tight exhaust valve seeing that the sound comes from the exhaust also.Anyone knows what can be causing this? dont want to start messing with valves /fuel tank unless i have to. Thanks
check the plugs...worn out?
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
