Old 03-27-2011, 04:46 AM   #1
fantasma87
fantasma87's Avatar
ok to remove the dash you have to remove the 2 screws behind the small ashtray next to the lighter on top of the radio. then remove the shift knob , remove one screw on the bottom of the shifter on the driver side, remove the bessell " just pull it" disconnect 2 connectors from the lighter and the emergency switch after that you will remove one screw under the dash on the driver side under the switches " fog lights, cruise control etc" then remove the pannel , you dont have to disconnect the connectors. you will see like 4 or 5 screws for the cluster, remove 4 screws on top of the cluster wich are the ones holding that black trim , then theres like 4 more screws behind it. you can pull the cluster but be carefull no to break the needle in front of it. remove like 4 connectors behind it. when you put it back make sure you can see the green male plug for the speedometer that will go inside the female side then you can push it in place. hope it helps for you. good luck, hey if you want , you can remove the front face of the cluster and paint it , to do it just remove all the screws that are holding it from the back and theres like 2 screws hidden behind the air vents , so you will need to remove them.
about the noise on the engine thats because you have air in the cooling system , place the car on a hill face up and let it run untill it warms up just a little so you can open the radiator cap so the air will make its way out. then fill it up. about the steam , i really dont know but it can be a hose leaking antifreeze or a bad clamp.
ARMY STRONG !!
