Old 03-17-2011, 02:11 AM   #7
El_supracabra
El_supracabra is on a distinguished road
Yes it is a 7mge. OF COURSE I used assembly lube. Lol
I was wondering if maybe the flywheel was too thick or something (perhaps causing the pressure plate not to release the clutch? Idk)
I'm not home right this minute, but I will def try to turn the motor "backwards" by hand a little to "dislodge" or realign whatever is "jamming". I think my clutch cylinder may need to be bled. Weird considering I didnt disconnect any hydraulic clutch lines. I did notice my resevoir was almost empty.... But that still wouldn't cause the thing to lock up that tight. I'm wondering if maybe I should loosen the bellhousing bolts a little to see if that helps loosen things up? Or maybe put it in gear and try to turn the driveshaft?
Anyways thanks a lot guys. Keep the suggestions coming, and I will def let you know what I find!
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
