Old 02-20-2011, 04:47 AM   #1
Without any idea as to your mechanical aptitude I couldn't tell you. A good set of spring compressors, the ability to find all the hidden screws to remove the trim in the trunk and the ability to turn a wrench and put things back how they were before is about all you need. Being careful with separating the springs from the dampers is the only part where you need to exercise care.... the stockers have more preload than the Eibach's so taking them off you need to use a spring compressor to compress them before taking off the hat.
