Old 02-17-2011, 04:27 AM   #1
ahruizguerra
ahruizguerra is on a distinguished road
Originally Posted by Rob1 View Post
well i always change the oil when i buy a new car so i know how many miles on the oil change for sure. but getting it tested is not a bad idea. but i still cant figure out why oil on dip stick is so clean i think im going to pull the pan and figure out whats going on before it potentialy costs me my motor.
i need to any way cuz i want to know what the previous owner had is the bottom end. Any way to pull pan without pulling motor and trans?
and also where can you get replacment oil squirters? and anyone know how much they cost? if i pull the pan i will probly replace them just to be safe i doubt anyone else has.
That's a good idea. When I replaced the head gasket, I decided to replace the piston rings and connecting rod bearing, so I had to removed the pan. I was impressed how much gulk i had inside my pan, between the metal plate. It took me HOURS to clean it.
ahruizguerra is offline   Reply With Quote
