Old 02-16-2011, 09:46 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by wcrispino View Post
Hey,
I made a special tool, I got a steel bar and welded the socket to the end of it. I then put a pipe at the end of that as well to get leverage. When we tried to pull on it, it started to bend the steel bar!! I have no idea why its so friggin tight. Is there anything else I can do!!!!?????
Sound like you need a thicker/stronger, and possibly longer steel bar. Again, step 1 is to get enough power on it. After that depends on exactly what happens *when* (not if) you get it to turn. I guarantee 100% that if you get enough power on it, something will happen.
Hopefully you're using a six-sided impact-grade socket.
You are turning it counterclockwise, right? Sorry...I had to ask.
Life begins at 30psi.
