Thread: Blue Smoke....
Old 02-16-2011, 09:40 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Travis89Turbo View Post
Sorry I should of read what section this was in. The ct12b on the 2j are good quality turbos. The valve seals that were used for some reason have a high failure rate... I used felpro seals as a replacement cuz they are made of a Viton rubber which is very durable..
Here is a good how to....
http://www.mkivsupra.net/vbb/showthr...al-Replacement
Ps. Get the valve spring tool it is worth the money.. I used long long nose needle noses to pull old seals out and it worked good! But get the valve keeper tool!
Here's what I consider to be an even better Valve Stem Seal article:
http://bellsouthpwp2.net/p/w/pwpanas...ra%20Turbo.htm
...however I am a bit biased. Read the article and you'll see why.
Life begins at 30psi.
