Old 02-10-2011, 08:15 AM   #1
Originally Posted by MADMKIII View Post
i see well i dont think ill be doing my own tunning i have no idea of how it works so i dont want to take a chance on messing something up, i see lots of peps here say to do the lexus afm and injector change but its not nessesary for 350ish whp is it? and i can get ahold of a apex-i safc I locally are those any goood?
The larger injectors are preferable to just increasing pressure. Increasing pressure may result in an a finer spray pattern and increased flow but the injectors may leak sooner than otherwise too. I suggest working all angles; larger injectors pushing their top rated pressure at a medium-low duty cycle.
What I don't like about the Lexus AFM housing + 550cc/min injector upgrade is that it's a blind upgrade. The assumption is that with an even increase in air and fuel that there's no difference but that's never the case and there's ALWAYS room for improvement; Fuel maps aren't just some linear graph. The Lex housing doesn't provide any major reduction in airflow restriction to make it worthwhile if you're also using a fuel controller.
A fuel controller (which actually only controls how much air the ECU is seeing) servers pretty much the same purpose as the Lex housing... it lies. The difference is that with the controller you have.. wait for it.. control! You have control over how much air the ECU is being told is or isn't coming into the engine and at which RPM and load level. Personally, I wouldn't run a lex housing unless I got it for $20..... and then I'd still be adding a fuel controller and doing some tuning.
The Lex housing isn't a bad idea; As they say "every little bit helps". But, it's not the first thing on my shopping list.
