Old 11-02-2010, 03:33 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Originally Posted by MJG View Post
Having not experienced the results first hand, have you checked your crank is not 180 degrees out from your cams?
I would doubt the engine would start, however, if it did???
It shouldn't, I've made that mistake before. Before anything, FIX YOUR AIR LEAK. Also, did you set your timing with the jumper wire in the diagnostic box? If you didn't, your timing will still not be properly set.
