Old 10-23-2010, 01:27 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by kylej View Post
If you go big single turbo your looking at 6000, the fuel system is about 2000 yeah, and exhaust can range alot between 800-1400, maybe even more. As for the rest its relatively cheap, besides an intercooler I guess you can get pretty expensive if your planning on running 1000+whp. Also I'd probably get a new clutch, I don't think the stock ones rated for that, haha.. I'm changing mine once I reach 600whp. And unless your planning on putting a stroker kit in it and spending 11000 your fine for dolla.
Actually you can get a relatively large single setup for more like $4,500 (not $6K). "The rest" of it is actually not cheap at all - for example an aftermarket ecu setup will cost about $2500. You'll need wider-than-oem rear rims to handle a single turbo, which is another $3K-$6K. The list goes on and on.
Your stock clutch won't handle anywhere near 600whp. Plan on replacing it at the 400whp level. Above 600whp or so you'll need a dual-plate clutch. Above approximately 800whp you'll probably need a triple-plate clutch.
Life begins at 30psi.
