Old 10-20-2010, 04:35 AM   #10
Sonyps307
I'm guessing u can put the swap in vortex I don't know but if the cams have more lift and longer Duration more air flow
Brain crower cams
Stage Description Part# Adv. Dur. Dur @ .050 Lift (in) Lift (mm) Kit# Dyno Shop Status
Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK.
Duration Lift
BC0321 264°/264° 220°/220° .336"/.336" 8.53/8.53 BC0320
Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires kit BC0320.
BC0322 272°/272° 226°/226° .342"/.342" 8.68/8.68 BC0320
USDM 7MGTE (’87-’92 MKIII) Stock
256°/256° 201°/201° .297"/.297" 7.54/7.54
