Old 10-12-2010, 04:19 PM   #2
Grandavi
Grandavi's Avatar
Originally Posted by Sonyps307 View Post
There is a gasket on the taillights if they leak the water will go to the spare also they r like 11-15$ at Toyota
Definitely brakelights.. especially if you see condensation in them after rain. I just did mine this weekend. they arent that difficult, but I did have to remove the panels a bit because I had trouble reaching 2 of the nuts. While you are doing the brakelight gaskets... pop off the white panel that holds the lights and make sure that the screw holding the ground is tight. Mine was backed off about 2 turns. (was causing my tail lights to flicker)
