Old 10-10-2010, 04:03 AM   #1
Grandavi
Grandavi's Avatar
I personally like the 57 trim in the CT26 housing. No real hassle adding it.. but it all depends on what your goals are. You already have the 550 CC injectors and fuel pump setup.. i assume you have the lexus afm for the ECU to control it properly.. and have opened up the engine with a 3" exhaust. Now its all dependant on if you have a good engine core to handle added boost. You dont want to kick an old engine hard unless your sure its not going to fold on you.
Can someone explain why I would want an aftermarket intercooler unless I was going for over 450 HP?
