Old 10-06-2010, 04:04 AM   #10
btwilson86
Super Moderator
btwilson86's Avatar
Originally Posted by Conga1991 View Post
does the cam position sensor have to be timed? from what I was told you just put it in and make sure the bolt that holds it is in the middle??
Yes, you have to time the CPS. No, you can't just drop it in. You have to line the gear up with the mark on the CPS, when you install it you have to compensate for the several degrees the whole thing is going to turn. Here is a link to the TSRM on how to PROPERLY install the CPS. Be sure you follow that last step (setting the ignition timing).
