09-17-2010, 02:23 AM
#1
Supra Owner
Originally Posted by localrager
Hello all, my name is Keith and I Just picked up a 94 TT yesterday. Car is mostly stock. 140k. Rebuilt at 93k.
Today (day after i get it) I get the Master Warning light. I check it.. "Check Engine" light flashes 1x then 4x so im guessing code 14 {Ignition signal}. What does this mean?
Also the "O/D off" light flashes 8x then flashes 9x. I dont know what that means if anything.
The car ran fine during test drive and the 1 1/2 hr drive home. No issues whatsoever.
Im new to the Supra so any help will be appreciated.
According to this...
http://www.mkiv.com/techarticles/eng...bd1_codes.html
... you have one ore more of the following: - Open or short in IGF circuit from igniter to ECM
- Igniter (problem)
- ECM (problem)
Most likely it's the first or second possibility. If you know of someone else with an Mkiv TT, try swapping out with his/her ignitor.
Life begins at 30psi.
