Thread: air mass sensor
Old 08-15-2010, 03:16 PM   #1
dont "think" you can just remove...
but i would suggest using one from a lexus. "maby some turbo users here can tell you what series to remove it from" its suposed to be around 25% more air.
or the maft pro.
but you will need the larger 550cc injectors aswell to add 25% more fuel. (i believe the 7mgte comes with 440cc)
also you could have just easliy searched this.
http://www.toyota-supra.info/forums/...onversion.html
http://www.toyota-supra.info/forums/...lator-pro.html
http://www.toyota-supra.info/forums/...ls400-afm.html
http://www.toyota-supra.info/forums/...lexus-afm.html
http://www.toyota-supra.info/forums/...af-sensor.html
http://www.toyota-supra.info/forums/...eter-swap.html
i could keep searching but this is your job, so get reading...
and if your not commited to searching and reading you shoudnt have a supra...
