Old 07-25-2010, 12:29 PM   #1
Paul_NJ
Paul_NJ is on a distinguished road
CRE
Thanks very much for your reply. That's a great electric diagram.
I may go down to Toyota myself to double check on availability of that relay. Now that I know where the relay(s) are, I'll pull them and check them out. I think the shop probably noted the fan wasn't running with A/C on, and that it did run when the relay was jumpered. Who knows?
I just got done reassembling everything after I replaced the timing belt, and it wouldn't be the first time I forgot to reconnect a wire or something . . . . good thing I'm not a surgeon
Can you rell me how to find a Bosch replacement?
Does it seem possible that a condenser overheat could put engine into cardiac arrest?
Paul
Paul_NJ is offline   Reply With Quote
