Old 06-30-2010, 12:18 AM   #1
well, replacing all the hoses is a pain in the ass but its well worth it as being stranded on the highway is not a head start.
it shouldnt be much to just buy some lengths for the sizes you need and then replace them ONE AT A TIME.
it will look good and you should be able to cancel out the hose theory if it continues.
did you get a compression check on head gasket??
because the hg blew on my samurai, and i knew right away because antifreeze started spraying out of my number 1 cylinder spark plug whole(it was not screwed in all the way).
