Old 06-22-2010, 04:14 PM   #10
Grandavi
Grandavi's Avatar
you should cam it
if you havnt done anything yet i suggest you remove stock airbox, and feed air filter under right headlight, and set it up with a good air inductionfilter!
also a great idea for you to heat wrap your intake it gets warm!
you could always set yourself up with a good clutch and lieght weight flywheel if your planning on going 5speed!
and dont worry about your hg it will blow one day... nothin you can do to stop it
so ride it harder until you can put in the MHG
Re: the Headgasket blowing.. I thought that was only with stock headgaskets torqued to factory spec (which is far too low). On a well maintained properly torqued OEM headgasket, it should last unless you bag it a lot. Is that correct?
The Metal head gasket, from what I understood is only necessary if your going to jump above 350 HP and only truly needed on the turbos with a turbo upgrade. I may be wrong, but that is what I gathered from reading.
