Old 06-13-2010, 04:53 AM   #1
Too long.
I took your question to mean that if you have a code 52 and it's not the wiring then what else would it be... the answer is on the same page as the diagnosis procedure reydio so kindly linked to: If not wiring then all that's left (with regard to that specific code) are the knock sensors and the ECU.
Have you even checked for codes yet or are we still speculating?
