Old 05-27-2010, 02:19 AM   #4
turbonicsperformance
turbonicsperformance is on a distinguished road
Originally Posted by nfa_automotive View Post
If you're worried about gas mileage. Check for leaking injectors, bad mass air, etc...etc...etc....Leave stuff alone and fix what is wrong. And why would the first thing you would think to go to is the timing. To get shitty gas mileage your timing would have to be REALLY f-ed up.
i wasnt looking at my timing for my milage it was just on the list of things to do and nothing seems to be broke i only have one code and it is iac code since i unplugged it and set my idle manually the only thing i could think of other than my afm or o2 was my timing not for my milage just as for my afr i have no leaks and my afm and o2 check out fine with a meter so i tried adjusting my timing and it did lean out a bit as i thought it would just not a whole lot... next step is checking the fuel pump when i bought the car it had everything that ive ever seen as a "gimmick hp adder" on the car it had the fart can exhaust ebay tornado turbo the magnetic fuel thing an air filter and im thinking he might have thrown in a pump for no real reason... but who knows thats what you get when you buy a used car
and ive gone through and checked and double checked everything before i even started driving it though today i built my new intake and wrapped my exhaust to prevent atleast a little heat soak (seems to be helping)
now at wot im running 13.6-12.5 loads better but still a little rich it should be around 14.0 at least i was shooting for 14.5-14.7 area right where its supposed to be but you can't always be perfect also today i found that this is not the original engine for my car when i pulled the heat shield off the manifold right there on the block is some paint markings form either a scrapyard or online company fun fun
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
